Текущее время: 19 май 2024, 15:50
 Страница 1 из 1 [ Сообщений: 19 ]
 Заголовок сообщения: bios MACBOOK AIR A1466.6.1 2013 ( A1466) A1466
СообщениеДобавлено: 28 июн 2014, 04:37
 Заголовок сообщения: Re: bios MACBOOK AIR A1466.6.1 2013 ( A1466) A1466
СообщениеДобавлено: 17 июл 2014, 17:51
Greate file but after reflash the MacAIR is acting strange,poor performance and lag in browsing.
Do you manage to fix this problem?
СообщениеДобавлено: 04 ноя 2014, 15:07
thank you so much
СообщениеДобавлено: 13 янв 2015, 18:19
Today I know only two solutions - viewtopic.php?f=51&t=27379 and viewtopic.php?f=51&t=27380
СообщениеДобавлено: 04 фев 2015, 17:01
what revision of motherboard for that dump?
СообщениеДобавлено: 13 мар 2015, 13:27
Hi
The file has a dirty me region you can't just use a donor bio's like that you must rebuild the me region with new hm86 and then rebuild it using the intel fit tool. Here is the file i re did it you should have no more problem
techman1025
СообщениеДобавлено: 06 апр 2015, 02:39
techman1025 hi what is the Intel fit tool? can you please explain how to mod these new apple bins please.
СообщениеДобавлено: 07 июл 2015, 06:18
Hi
Like i said you can't just use a donor bios once a computer boots it married to that computer so what will happen reboots fans running full speed lagging ...slow and so on ...so you need to rebuild the ME REGION is done by using the intel fit tool for that chipset so for new say i5-4th gen you would use the intel fit tool 9&10 ...so say you have a donor bios there is two way of doing it first and easies is just take the 4mb of the original file and merge the bottom half with donor bios then just replace serial done....so say if the original is currupted then you need to find a clean me region say four the Z87 chipset so you could search for a full never used dump from hp ,acer drop it in the fit tool and it make a a folder with your new never used me region then you need to compare with original file when done click rebuild save it open text editor and past new me region in your apple macbook that uses the same z87 thats how it done .
techman1025
СообщениеДобавлено: 19 июл 2015, 14:30
Its a problem becouse 2012 - 2014 year model have security checksum and i cant brake this ...
СообщениеДобавлено: 18 авг 2015, 22:20
Where can I get this intel fit tool please?
СообщениеДобавлено: 18 авг 2015, 23:21
Заблокирован
Strange. I making clean ME region without intel fit tool.
and I never heard about any checksum.
СообщениеДобавлено: 19 авг 2015, 13:52
How? Where can I find info what this is exactly? Is it just a reagion that needs to be ff'ed out?
Posted after 3 hours 58 minutes 22 seconds:
Is it possible to get a clean bios file for every model without modifying it (without changing the serial number)?
Posted after 1 minute 11 seconds:
Are those files here in forum already clean or do I still need to modify them?
СообщениеДобавлено: 19 авг 2015, 19:56
Заблокирован
Where do you can find info about it? I think nowhere. I figured it out by myself.
Yes you right. It is possible to create clean factory BIOS for every model. Only thing you need is to manually add SN and MLB using any Hex editor.
Of course they are not here. If you want any dump PM me :)
СообщениеДобавлено: 20 авг 2015, 11:23
Thanks a lot gnommak!
СообщениеДобавлено: 14 сен 2015, 18:13
Hi
So everybody knows YOU CAN'T MAKE A CLEAN ME REGION WITH JUST A TEXT EDIT PROGRAM. It needs to be rebuild with the correct intel fit tool for that chipset. so if it's a qs77 chipset you need to download from any site that as a full update and uses that same qs77 chipset and lot of info on the net just google it . Also you can't just cut the me region out of a new clean update with a text editor each laptop uses different setting even know it's the same chipset .
Techman1025
СообщениеДобавлено: 28 ноя 2015, 19:19
Здравствуйте. У меня та же проблема полный блок биос. Нужно ввести 4-х значный пароль. Помогите уважаемые. У кого есть дамп биоса скиньте на dmi-otyakov@yandex.ru пож-та.
СообщениеДобавлено: 27 дек 2015, 10:35
where the tool release intel thanks
СообщениеДобавлено: 27 дек 2015, 19:25
hi,what tools used please!!!
СообщениеДобавлено: 21 фев 2016, 10:58
hi,please I need extract file .fd of scap of mac,thanks
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MacBook air a1466 820-3437А ( a1466 820-3437А) MacBook air a1466 25q064a 820-3437А или (В) bios dump help
в форуме Apple
djkomix
12076
03 май 2016, 16:52
djkomix Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MacBook Pro 15 2013 (A1398) MacBook Pro 15 2013 выключается хаотично, проверьте Дамп!
в форуме Apple
Saip
4903
25 апр 2018, 14:31
Saip Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Macbook air (A1466 2013) Problem Error code 8877652
в форуме Apple
sifocool
24 сен 2014, 06:14
retsu Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Macbook air (A1466 2013) need dump 820-3437-b
в форуме Apple
sifocool
08 май 2017, 11:13
krokozjbr Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MacBook Air A1466 2013 (820-3437-B) вентилятор всегда крутится на максимуме
в форуме Apple
DMS
22
13560
10 июн 2017, 13:38
yleepka Перейти к последнему сообщению
Сейчас этот форум просматривают: Tves и гости: 10
