Текущее время: 28 май 2024, 17:08
dany_l2003
Заголовок сообщения: Re: bios MACBOOK AIR A1466.6.1 2013 ( A1466) A1466 Добавлено: 17 июл 2014, 17:51 |
Зарегистрирован: 06 авг 2013, 17:30 Наличности на руках: 101.10
Сообщения: 52 Откуда: Romania
mohamedxp2 писал(а): bios MACBOOK AIR A1466.6.1 2013 Greate file but after reflash the MacAIR is acting strange,poor performance and lag in browsing. Do you manage to fix this problem?
Oblom
Заголовок сообщения: Re: bios MACBOOK AIR A1466.6.1 2013 ( A1466) A1466 Добавлено: 13 янв 2015, 18:19 |
Зарегистрирован: 21 окт 2011, 23:30 Наличности на руках: 274.35
Сообщения: 168 Откуда: Ukraine
dany_l2003 писал(а): mohamedxp2 писал(а): bios MACBOOK AIR A1466.6.1 2013 Greate file but after reflash the MacAIR is acting strange,poor performance and lag in browsing. Do you manage to fix this problem? Today I know only two solutions - viewtopic.php?f=51&t=27379 and viewtopic.php?f=51&t=27380
techman1025
Заголовок сообщения: Re: bios MACBOOK AIR A1466.6.1 2013 ( A1466) A1466 Добавлено: 07 июл 2015, 06:18 |
Зарегистрирован: 12 апр 2014, 03:48 Наличности на руках: 51.00
Сообщения: 14 Откуда: usa
Khan_G писал(а): techman1025 hi what is the Intel fit tool? can you please explain how to mod these new apple bins please. Hi Like i said you can't just use a donor bios once a computer boots it married to that computer so what will happen reboots fans running full speed lagging ...slow and so on ...so you need to rebuild the ME REGION is done by using the intel fit tool for that chipset so for new say i5-4th gen you would use the intel fit tool 9&10 ...so say you have a donor bios there is two way of doing it first and easies is just take the 4mb of the original file and merge the bottom half with donor bios then just replace serial done....so say if the original is currupted then you need to find a clean me region say four the Z87 chipset so you could search for a full never used dump from hp ,acer drop it in the fit tool and it make a a folder with your new never used me region then you need to compare with original file when done click rebuild save it open text editor and past new me region in your apple macbook that uses the same z87 thats how it done . techman1025
gnommak
Заголовок сообщения: Re: bios MACBOOK AIR A1466.6.1 2013 ( A1466) A1466 Добавлено: 18 авг 2015, 23:21 |
Зарегистрирован: 06 фев 2015, 20:32 Наличности на руках: 60.03
Сообщения: 53 Откуда: дом Заблокирован
dupahuj писал(а): Its a problem becouse 2012 - 2014 year model have security checksum and i cant brake this ... hondavtec писал(а): Where can I get this intel fit tool please? ??? Strange. I making clean ME region without intel fit tool. and I never heard about any checksum.
hondavtec
Заголовок сообщения: Re: bios MACBOOK AIR A1466.6.1 2013 ( A1466) A1466 Добавлено: 19 авг 2015, 13:52 |
Зарегистрирован: 18 авг 2015, 22:06 Наличности на руках: 18.08
Сообщения: 16 Откуда: Germany
gnommak писал(а): I making clean ME region without intel fit tool. How? Where can I find info what this is exactly? Is it just a reagion that needs to be ff'ed out? Posted after 3 hours 58 minutes 22 seconds:Is it possible to get a clean bios file for every model without modifying it (without changing the serial number)? Posted after 1 minute 11 seconds:Are those files here in forum already clean or do I still need to modify them?
gnommak
Заголовок сообщения: Re: bios MACBOOK AIR A1466.6.1 2013 ( A1466) A1466 Добавлено: 19 авг 2015, 19:56 |
hondavtec писал(а): How? Where can I find info what this is exactly? Is it just a reagion that needs to be ff'ed out? Where do you can find info about it? I think nowhere. I figured it out by myself. hondavtec писал(а): Is it possible to get a clean bios file for every model without modifying it (without changing the serial number)? Yes you right. It is possible to create clean factory BIOS for every model. Only thing you need is to manually add SN and MLB using any Hex editor. hondavtec писал(а): Are those files here in forum already clean or do I still need to modify them? Of course they are not here. If you want any dump PM me :)
dmitrix
Заголовок сообщения: Re: bios MACBOOK AIR A1466.6.1 2013 ( A1466) A1466 Добавлено: 28 ноя 2015, 19:19 |
Сообщения: 3 Откуда: Северск
Здравствуйте. У меня та же проблема полный блок биос. Нужно ввести 4-х значный пароль. Помогите уважаемые. У кого есть дамп биоса скиньте на dmi-otyakov@yandex.ru пож-та.
