Текущее время: 17 май 2024, 09:25
 Заголовок сообщения: Не могу найти аналог RT9079-33GJ5  [РЕШЕНО]
СообщениеДобавлено: 18 апр 2022, 19:30
36V, 50μμμμμA I Q, Peak 200mA Low Dropout Voltage Linear
Regulator
Цитата:
RT9079
DS9079-03 March 2019 www.richtek.com
©Copyright 2019 Richtek Technology Corporation. All rights reserved. is a registered trademark of Ric htek Technology Corporation.
Features
 50μμμμμA Ground Current at no Load
 Maximum Operating Input Voltage 36V
 ±±±±±2% Output Accuracy
 100mA Continuous Output Current
 Less than 0.1μμμμμA Disable Current
 Dropout Voltage : 0.2V at 10mA
 Support Fixed Output Voltage 2.5V, 3V, 3.3V, 5V,
6V, 9V, 12V
 Stable with Ceramic or Tantalum Capacitor
 Current Limit Protection
 Over-Temperature Protection
 RoHS Compliant and Halogen Free
Цитата:
RT9079
Electrical Characteristics
Parameter Symbol Test Conditions Min Typ Max Unit
Supply Voltage V CC 3.5 -- 36 V
Output Voltage Range V OUT 2.5 -- 12 V
DC Output Accuracy VOUT I LOAD = 10mA 2 -- 2 %
Dropout Voltage V DROP I LOAD = 10mA, VCC > 5V -- 0.2 0.36 V
VCC Consumption Current I Q I LOAD = 0mA, VCC = 15V -- 50 100 A
Shutdown Current V EN = 0V -- 0.1 0.5 A
Shutdown Leakage Current V EN = 0V, VOUT = 0V -- 0.1 0.5 A
EN Input Current I EN V EN = 36V -- 0.1 -- A
Line Regulation VLINE
I LOAD = 1mA,
V OUT +1 < VCC < 36V, V OUT  3.3V -- 0.04 0.5
I LOAD = 1mA,
V OUT +1 < VCC < 36V, V OUT  3.3V -- 0.04 0.6
Load Regulation VLOAD 0mA < I LOAD < 100mA 1 -- 1 %
Output Current Limit I LIM V OUT = 0.5 x VOUT(normal) 200 350 -- mA
Enable Input
Voltage
Logic-High V IH -- -- 2 V
Logic-Low V IL 0.6 -- --
Thermal Shutdown Temperature T SD I LOAD = 30mA -- 150 -- °C
Thermal Shutdown Hysteresis T SD -- 20 -- °C
 Заголовок сообщения: Re: Не могу найти аналог RT9079-33GJ5
СообщениеДобавлено: 19 апр 2022, 13:07
По распиновке, входному напряжению и току подходит S-19212D33A-M5T1U https://eu.mouser.com/datasheet/2/360/S ... 714017.pdf
СообщениеДобавлено: 19 апр 2022, 13:37
спасибо большое, я и по калькулятору на сайте искал производителя.... Может есть лайф хак, как находить такие компоненты..
что-то тяжеловато с деталями сейчас, половину сайтов не открывает ((( нет доставки,.. на али тоже не находит.... жаль
СообщениеДобавлено: 19 апр 2022, 14:14
dillinja писал(а):
Может есть лайф хак
Да вот на том же маузере можно искать https://eu.mouser.com/c/semiconductors/ ... e=SOT-23-5
Ну это да, пока не устаканится либо с доноров, либо обходные пути искать...
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ZD5245BS2 zenner diode аналог. Помогите подобрать аналог
geksogenchik
10 окт 2018, 13:03
geksogenchik Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. помогите найти аналог где встречаются транзюк 2N7002KW и TP0610K-T1-E3
-=ShaMan7=-
10477
27 мар 2016, 18:01
FC1989 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. помогите найти аналог транзистора
Акром
12 окт 2014, 08:58
Акром Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Помогите найти аналог мосфета TPCC8067-H (даташит в комплекте темы)
Tves
08 апр 2015, 13:23
Tves Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo G580 (compal) не могу найти аналог транзистора
sssr111
2649
30 май 2015, 14:22
sssr111 Перейти к последнему сообщению
Сейчас этот форум просматривают: ekibastuz2015 и гости: 4
