Заголовок сообщения: xbox one a12-220p1a external power supply fault help
Добавлено: 01 авг 2021, 19:09
Зарегистрирован: 27 фев 2020, 13:07 Наличности на руках: 303.76 Сообщения: 295 Откуда: romania
Hello i have 2 power supply a12-220p1a(the external ones for original xbox one) that manifest same fault ; this was tested on 2 xbox one in 2 different location; they work ok but from time to time it can be 5h or in first second at power on when they stop and the led is off; i measured inside and in the DC side the management ic (CP053WD which i can't find anywhere any pdf or data) i think it pulls pin 16 to ground (some protection or something ) ; This open an mosfet that pulls the 5V to ground trough a resistor of high wattage; this resistor become very hot climbing to 100+*C if you don't remove the 220V ; anyone can help me with something? thanks
ilie321
Заголовок сообщения: Re: xbox one a12-220p1a external power supply fault help
Добавлено: 02 авг 2021, 10:10
anyone can help Those 4 capacitors for 12v and 5v seams ok... Under 10% loss of value and esr ~0.8 at list the pinout of that ic
Вложение:
ilie321
Добавлено: 04 авг 2021, 19:07
If i force manually the source to start and i put load of 5-6A no problem. I don't understand what is wrong but both have same behavior
alekst07
Добавлено: 06 авг 2021, 09:23
Зарегистрирован: 14 июл 2011, 20:31 Наличности на руках: 30.00 Сообщения: 44 Откуда: Русский Сибиряк
Когда неисправность плавающая, то в первую очередь проверьте все электролитические конденсаторы.
ilie321
Добавлено: 09 авг 2021, 12:22
already did this all are ok esr and capacity i think that IC has some problems CP053WD but is nowhere to find datasheet
ilie321
Добавлено: 23 авг 2021, 12:05
Anyone know what ic is this?
Вложение:
