Текущее время: 08 май 2024, 20:12
 Заголовок сообщения: Biostar Hi-Fi A88S3E
СообщениеДобавлено: 09 июн 2021, 20:50
Hi sorry I can't speak russian. I have a problem with this motherboard. It will power on, but debug card says 00 and there is a red light for motherboard.
I checked all the mosfets under the heatsink and they appear to be fine:
There is 12V going into each of the SM4377 MOSFETs, but there is no output voltage, so there is no voltage going into the SM4364 MOSFETs.
I can see a gate driver on the left with marking 8BC. I believe this is ISL6208BCRZ. The capacitors around the driver are showing 5V and 4.7V, so perhaps this driver has gone bad?
Also, and this is probably not important until the MOSFETs have voltage but I also looked at the capacitors near the CPU socket. The four on the right appear to be burnt. When measured with multimeter in resistance mode, they do not increase in resistance. Also when removing the capacitors they show no capacitance. When I checked two of the capacitors on the left hand side they measured 25uF - this seems to be a very odd number?
Thanks
 Заголовок сообщения: Re: Biostar Hi-Fi A88S3E
СообщениеДобавлено: 10 июн 2021, 19:28
Извините за перевод Google
Я сделал трассировку, драйверы ISL6208BRZ управляются ШИМ-регулятором ISL62773. Я получаю 5В на VDD, VDDP и VIN. 0V на ENABLE, PWROK и PGOOD. Как мне узнать, какие из этих трех последних необходимы для включения ИС?
I did a trace, the ISL6208BRZ drivers are controlled by PWM regulator ISL62773. I'm getting 5V on VDD, VDDP and VIN. 0V on ENABLE, PWROK and PGOOD. How do I know which of these last three are needed to turn on the IC?
Для PGOOD я отследил 5 В от VDD, но этот компонент, обведенный желтым, кажется, останавливает 5 В от перехода на PGOOD. Что это за компонент?
For PGOOD I traced 5V from VDD but this component circled in yellow appears to be stopping 5V from going to PGOOD. What is this component?
СообщениеДобавлено: 10 июн 2021, 23:02
отправил на почту борду с похожей материнки.
надеюсь поможет ))
СообщениеДобавлено: 11 июн 2021, 13:39
Do a work step by step. There is such thing as Power Sequence. Voltages and signals appear in order. So check it in that order. All previous voltages, powergood signals must be OK, before EN to ISL62773 rise up to logical 1.
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 26 июн 2021, 21:25
Я нашел pdf-файл для моей материнской платы версии 6.3 (моя материнская плата - версия 6.0).
I found a pdf for version 6.3 of my motherboard (my motherboard is version 6.0).
Конденсаторы, которые сгорели в разъеме ЦП, имеют емкость 22 мкФ, так что я могу их заменить.
The capacitors which were burnt at the CPU socket are 22uF, so I can replace those.
Изображение Изображение
Проверил напряжения PWM_EN и CPU_PWRGD. Они оба получают правильное напряжение, но на другой стороне обоих резисторов 0 В. Не понимаю почему. Я попытался заменить резистор 1K на новый, проблема все та же. Когда я распаял резистор 10 кОм, он показал 10,02 кОм, что тоже нормально.
I checked the PWM_EN and CPU_PWRGD voltages. They are both getting the correct voltage, but the other side of both resistors is 0V. I don't understand why. I tried replacing the 1K resistor with a new one, still the same problem. When I desoldered the 10K resistor it read 10.02K which is also ok.
Я думаю, что JP4 контролирует последовательность питания процессора. Я не уверен, что 3,3 В означает 1 или 0? Независимо от того, что я получаю 3,3 В
I think JP4 controls the CPU power sequence. I'm not sure if 3.3V means 1 or 0? Regardless I get 3.3V
Что интересно, теперь плата не будет оставаться включенной, если отладочная карта установлена в слот PCI. Он включится на несколько секунд, а затем выключится.
Interestingly the board will now not stay powered on if the debug card is installed in the PCI slot. It will turn on for a few seconds, and then turn off.
В этой теме нет новых непрочитанных сообщений. biostar nf550 am2 включается нет изображения POST CODE 23
в форуме Biostar
Greengophantom
08 дек 2014, 18:06
Серпантин Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Нужна схема BIOSTAR A960D+ Ver. 6.1
в форуме Biostar
ukcomputer
23 окт 2014, 12:57
ukcomputer Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. помогите опознать мосфеты Biostar nf4 4x-a7
в форуме Biostar
nazar
26 ноя 2014, 14:18
nazar Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Biostar GF7050-M2 Зависает при подключении флешки более 1Гб
в форуме Biostar
hazya
05 фев 2015, 15:04
hazya Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Biostar nf520-a2 LE ver.6.4
в форуме Biostar
Spawn_84
12
8889
14 дек 2014, 21:17
NEME$I$ Перейти к последнему сообщению
