Текущее время: 02 июн 2024, 01:36
 Страница 3 из 4 [ Сообщений: 109 ]  На страницу Пред.  1, 2, 3, 4  След.
 Заголовок сообщения: Re: toughpower-grand-rgb-80-plus-gold-850 help
СообщениеДобавлено: 08 июл 2020, 11:46
ilie321 писал(а):
I forced the controller to start and I put 10 to 20v DC instead of 400 to see the waveform
Are sinusoidal distortions of rectangular pulses related to overload or insufficient power supply 10 - 20 V ?
СообщениеДобавлено: 08 июл 2020, 13:43
Oh those were because of my crap oscilloscope and I can't edit older posts . I passed to devide by 10 on probe and no distortion. Signal look decent square wave on primary coil to ground.
At 20v on input coil to ground I get a Vpp of around 15V (square wave) . If I measure directly on the coil signal looks like sin wave and has around 500mVpp at 20v input. If at 20v it is 500mv at 400 will be 10v maybe?
Вложение:
СообщениеДобавлено: 08 июл 2020, 17:18
Maybe.
СообщениеДобавлено: 09 июл 2020, 13:32
I forgot to mention that the rectifying bridge has one diode the a like 20-30 points lower value than the other 3. I used a 12Vac source and I injected on input of psu and with oscilloscope I measured on big capacitor for any distortions. I found nothing . Can this cause problems at 400v?
СообщениеДобавлено: 09 июл 2020, 23:29
Bridge is in the circuit or desoldering ?
СообщениеДобавлено: 10 июл 2020, 10:30
In circuit. I put 12Vac instead of 220V in psu. I got no distortion at 12v.
СообщениеДобавлено: 10 июл 2020, 21:11
I want to build this to test smps transformers
https://www.google.ro/url?sa=t&source=w ... KrxUuzZNsm
СообщениеДобавлено: 15 июл 2020, 01:14
You should change this bridge by a new one for your safety )
Mosfet gate transformer has 1.356mH @ 1kHz 1 - primary and 2 separate secondary coils.
Primary coil of the main transformer - 752uH, 180nF capacitor, 62uH - aux L.
Measured in Zalman 750EBT psu. Also it has 2 PWM mosfets dead - 5r190CE, one IRFB7437 in sec. side, bridge GBU1506, FUSE/ Maybe something else )
-приворот winDOвSa
-розыгрыш автоБАНа
В сети
СообщениеДобавлено: 15 июл 2020, 07:27
Wew then my transformer maybe it has a short. I tried to measure inductance on primary coil directly in circuit and I was unable (I have a cheap fcl meter}. I measured a bigger coil and add it in series and the difference was 1-2uH for primary hmmm. It can have such low inductance? From a paper I read they say yes but I don't know. I tried to build that blue coil ringer from the link in last post but I don't have the cd4015 so I put oscilloscope directly instead of the ic to see the impulses. On some coils I can see 5 6 impulse but on primary of the transformer maybe 1 pulse. Any other way to measure that transformer is OK? Maybe I will desolder it. If it is dead any chance to find other or repair it? Thanks
СообщениеДобавлено: 15 июл 2020, 16:19
What is your advice (read last post) thank you
СообщениеДобавлено: 15 июл 2020, 21:52
Primary coil of the main transformer in no LLC PSU - 1.5mH, so if you have <750uH - it's strange.
Measure it without circuit.
-приворот winDOвSa
-розыгрыш автоБАНа
В сети
СообщениеДобавлено: 15 июл 2020, 22:53
It an no llc psu? It is llc
СообщениеДобавлено: 16 июл 2020, 00:33
Must be around 700-1500 uH. If < - transformer possibly dead.
-приворот winDOвSa
-розыгрыш автоБАНа
В сети
СообщениеДобавлено: 16 июл 2020, 07:09
It is 1-2uH :( anything I can I do? It can drop from 700+uH to 1?
СообщениеДобавлено: 16 июл 2020, 17:36
take a photo of the transformer please.
-приворот winDOвSa
-розыгрыш автоБАНа
В сети
СообщениеДобавлено: 16 июл 2020, 21:22
Вложение:
СообщениеДобавлено: 17 июл 2020, 00:09
must be about 750uH
-приворот winDOвSa
-розыгрыш автоБАНа
В сети
СообщениеДобавлено: 17 июл 2020, 14:40
Thank you. I can't get it out from circuit witn 60w iron :(. Hot air will distroy pcb I think. Any chance if transformer is in short to do something? Replace it or repair it?
СообщениеДобавлено: 17 июл 2020, 15:15
No need to get it out from circuit. Remove only MOSFETs as I did and measure the coil. As you can see your and mine PSU have the same platform. Dead main transformer - very rare situation.
Replace it or repair.
-приворот winDOвSa
-розыгрыш автоБАНа
В сети
СообщениеДобавлено: 17 июл 2020, 16:11
Ok thank you. Where I can buy this? Aliexpress? The code is strange on it what to search?
Also how to remove it?
СообщениеДобавлено: 17 июл 2020, 17:47
only from psu on the same platform and power. There is no other options.
-приворот winDOвSa
-розыгрыш автоБАНа
В сети
СообщениеДобавлено: 17 июл 2020, 18:05
Repair transformer any chance? I desolder it and same readings 1uH. Aux coil has 50+uH and caps 180nF
I have seen on YouTube that they boil them to open magnetic core. But after you need special glue or something? And I can use same wires and same protection tape or is destroyed?
СообщениеДобавлено: 18 июл 2020, 12:07
Depends on topology, some transformers have an unmagnetic gap in the central, some not.
Yes. Be careful.
Need to replace a shorted wires by a new one. Very important to turn it wire by wire. Also in right direction.
Mylar is used as an isolator. Also you can use Captone.
-приворот winDOвSa
-розыгрыш автоБАНа
В сети
СообщениеДобавлено: 18 июл 2020, 20:50
I was unable to open it without breaking it :( they put melted plastic over the ferite and I was unable to remove it without breaking the core. Sad. The primary was in short after I open it I detected that easy. Any chance to find another transformer somewhere similar to this? It will not work if glued like this no? :)
СообщениеДобавлено: 19 июл 2020, 02:15
it is an epoxy compound. You must boil transformer before try to remove it. You can buy core or try to open another one. It is STD-39 (39mm width)
It is important to set up right nonmagnetic gap.
-приворот winDOвSa
-розыгрыш автоБАНа
В сети
СообщениеДобавлено: 19 июл 2020, 08:15
I boiled it the core separate in both but the melted thing did not let it free. I use a screwdriver and by mistake i break it. The center is not round so hard to find replacement ferrite. It is oval.
СообщениеДобавлено: 19 июл 2020, 16:05
Take a photo of your transformer now.
-приворот winDOвSa
-розыгрыш автоБАНа
В сети
СообщениеДобавлено: 19 июл 2020, 16:57
I glue it I will try to assemble and see if I get 750 uH but I doubt it will work again.
Вложение:
Вложение:
Вложение:
Posted after 2 hours 15 minutes 17 seconds:
I reassembled it as I could and I have like this:
No core inserted primary coil 13uH
With core as close as I can press with hands has 330uH hmmm :( . Maybe is different from that with 750uH?
СообщениеДобавлено: 19 июл 2020, 23:56
primary coil consist of 2 coils. did you assebly as it was? number of turns, winding rotation, and so on? Your core looks like normal.
It also may help someone someday if you write here N of turns
For example:
I - 50 turns d=0.5мм
II - 10 turns 3x0.6mm
-приворот winDOвSa
-розыгрыш автоБАНа
В сети
СообщениеДобавлено: 20 июл 2020, 08:22
Primary is only 1 coil made of many very small wires in paralel so diameter is hard to tell because you can't make circle (it is around 1.5mm) 28 turns . And secondary is made from copper foil put on some isolator and has 15mm wide with 4 turns with median connector. Second coil for - 12V it has 2turns of 0.5mm. Yes used same direction. Only at the - 12v coil I'm not sure of direction of those 2 turns.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Thermaltek Toughpower Grand RGB 750W. Нет старта. Дежурка есть
[ На страницу: 1, 2 ]
Sergey183
43
7069
25 сен 2020, 09:56
Sergey183 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Thermaltake toughpower grand rgb 850w интеерсеный случай!!!
Zuev777
3057
12 фев 2021, 00:34
Zuev777 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Toughpower Grand RGB 1200W Platinum SHORT-CIRCUIT
PT-AH
25 окт 2023, 09:20
Radio2865 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Bios dump elitebook 850 G1 (Bios dump elitebook 850 G1) Bios dump elitebook 850 G1
zenelli
23752
23 мар 2015, 23:14
zenelli Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Thermaltek Grand RGB 750W. Прошу помочь опознать транзистор.
Sergey183
2477
14 июл 2020, 18:21
