Текущее время: 18 май 2024, 06:31
ilie321
Заголовок сообщения: need some help for ati cards with memory errors for making script Добавлено: 19 мар 2020, 16:58 |
Зарегистрирован: 27 фев 2020, 13:07 Наличности на руках: 313.76
Сообщения: 295 Откуда: romania
hello i edited the script from here viewtopic.php?f=48&t=91866&p=683466&hilit=%2A%D1%81%D0%BA%D1%80%D0%B8%D0%BF%D1%82%2A#p683466I try to find an connection between software result and real damaged chips from ati amd cards if anyone has ati cards with memory errors and he know which chips are faulty on the board can give me some help please: go to the post above get arch linux make bootable usb; copy the new script from this topic; is in zip; you need to extract file first; put it on the root of the same usb after was made bootable (see how to make bootable in the link above) boot to usb type in console: cd .. cd /run/archiso/bootmnt/ python3 ./dmgg.py b0000000 1 16 and give me the result here also tell me the real bad chips from your card ; count from right to left with the pcie slot near you; dmmg.py is the name of this script from the usb b0000000 can be different ; you need to run in console 'lspci -v' search your ati card and check the memory for your ati card 1 is 1mb of memory which is enough; 16 is the number of the real memory chips from the card (i had 16 on my card for 8gb memory) so you put the number of chips from your card the result should look like this: Вложение: 20200319_142056.jpg
galkinvv
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 19 мар 2020, 18:27 |
Зарегистрирован: 09 янв 2017, 12:18 Наличности на руках: 250.39
Сообщения: 651 Откуда: Зеленоград
Correspondence between software addresses and physical memory chips for AMD can be found using a working card. The idea is to introduce temporarily noise in GPU-memory interconnections. - Take a working card, run test to besure that no errors are detected
- Use testpoint on the lead from memory chip to gpu to intoduce noise in the data. Those test points present on most AMD cards. From my experience holding the probe of a multimeter/oscilloscope is enough. If it is not enough - capacitor or resistor to ground should help.
- Run test again - it should fail on the memory chip that has noise for its GPU interconnection. Note the address.
- Release probe (or other noise source) - now the test should pass again, even without reboot.
- Steps above gives you correspondence for single memory-chip<->its-adress. Repeat for every memory chip - to find all adresses)
With some experience the correspondence can be approximated by measuring on gpu where some memory-modules are already not working (initial test doesn't pass). But for first-time-practicing I suggest to perform first experiment on some working (maybe some older) card. P.S. I'm original script author, and the method described above IS the method I use nowdays for AMD cards.
galkinvv
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 19 мар 2020, 20:38 |
I have a correspondence only for sapphire rx470 4gb - viewtopic.php?p=746565#p746565Цитата: First problem at: 0x0-0x1f0 - U2200+U2300 First problem at: 0x200-0x3f0 - U2000+U2100 First problem at: 0x400-0x5f0 - U2400+U2500 First problem at: 0x600-0x7f0 - U2600+U2700
ilie321
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 20 мар 2020, 10:26 |
for r9 390 seams to be like this from right to left starting near pci-e in circle Вложение: C671X r1.00X fz.png u2000 0x500 u2100 0x700 u2200 0x400 u2300 0x600 u2400 0x000 u2500 0x200 u2600 0x100 u2700 0x300 u2800 0x900 u2900 0xb00 u3000 0x800 ! u3100 0xa00 ! u3200 0xc00 ! u3300 0xe00 u3400 0xd00 ! u3500 0xf00 ! not 100% sure for "!" because mine are broken Posted after 2 hours 51 minute 50 seconds:question @galkinvv : i edited bios to have 4gb or even 2gb of ram (even density as on forums) for my card and i still get the same memory errors i have last 5 chips from left of pcie broken and i took them down this means that they start to count from the left? u3000 0x800 ! u3100 0xa00 ! u3200 0xc00 ! u3400 0xd00 ! u3500 0xf00 !
ilie321
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 20 мар 2020, 14:00 |
meohaimat2021 писал(а): you let me ask what jamming point are you measuring on C671X r1.00x ? that is just a picture to show the count order; i don't have any image/schematic for r9 390
ilie321
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 20 мар 2020, 14:35 |
meohaimat2021 писал(а): so where do you measure on that vga such as the equivalent of VREF or ZQ or the reset on vgaline? yes i do ( i put to ground for few seconds that point) and i get more errors if chips was good or no change if it was faulty Posted after 3 minutes 58 seconds:i made the script for r9 390 i dont have how to test others for the moment this is last version: Вложение: dmgg.zip
galkinvv
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 20 мар 2020, 19:05 |
ilie321 писал(а): question @galkinvv : i edited bios to have 4gb or even 2gb of ram (even density as on forums) for my card and i still get the same memory errors i have last 5 chips from left of pcie broken and i took them down this means that they start to count from the left? u3000 0x800 ! u3100 0xa00 !
u3200 0xc00 !
u3400 0xd00 ! u3500 0xf00 ! I had zero experience in partial disabling memory of memory modules, and always thought that it isn't known/possible on post-year2010 GPUs. Modern 8GB cards differ from 4ПИ cards with similar gpu not by memory chip count, but only by capacity of every module... What do you mean about "even density" edit? (google gives nothing about "even density" vbios ...)
ilie321
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 20 мар 2020, 19:56 |
It is written here: https://www.overclock.net/forum/67-amd/ ... 2?page=430"How to edit supported memory size & density Warning: Spoiler! (Click to show) Supported memory size in a rom is located in VRAM_Info table (ref Atomdis tables for a rom for beginning offset location of table). Currently HawaiiReader does not support this edit. Quick way of getting you to right area is doing a text string search in a HEX editor, you would be searching for the supported IC by rom to get to you that area. ICs that can be supported (if you find more post in thread so they can be added):- 4GB ROM EDW2032BBBG EDW2032BBBG_DEBUG2 H5GQ2H24AFR H5GC2H24BFR K4G20325FD K4G20325FS (so far only seen in Sapphire R9 290/X New Edition) 8GB ROM EDW4032BABG H5GQ4H24MFR H5GC4H24AJR A 40 denotes 4GB RAM and 80 denotes 8GB RAM. When 2 IC's are supported you would edit the appropriate one or both if creating a ROM being released for others to use. RAM density needs to be adjusted when using a 390/X ROM on 290/X. Code: 290X VRAM_info 0022: UCHAR ucDensity = 0x43 (67) 0028: UCHAR ucMemorySize = 0x40 (64) 390X VRAM_info 0022: UCHAR ucDensity = 0x53 (83) 0028: UCHAR ucMemorySize = 0x80 (128) Quote: Originally Posted by The Stilt View Post To get around the MEMCLK barrier in Grenada, AMD has latched some of the memory controller related timings (through bios). So for higher than 1375MHz use 390 memory block with corrected memory density and corrected timings. A 53 in the 390/X VRAM_Info needs to be changed to 43. When 2 IC's are supported you would edit the appropriate one or both if creating a ROM being released for others to use. Sreenshot for referencing plus extra info (Click to show) Use yellow underlined HEX values for ref plus ANSI text section in editor with supported RAM type. Right most window shows a 290 rom with 2 supported ICs, each colour of boxed HEX matches the same colour underlined supported IC, density is purple boxed hex values" Posted after 2 hours 46 minutes 19 seconds:galkinvv писал(а): Modern 8GB cards differ from 4ПИ cards with similar gpu not by memory chip count, but only by capacity of every module. Yeah true. So i need to find those replacement chips to make it work. Posted after 1 minute 4 seconds:meohaimat2021 писал(а): I have sent a message in the forum for you to see
Any news?
ilie321
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 24 мар 2020, 14:42 |
i added rx470 can you check if it gives good values? Вложение: dmgg.zip anyone else has ati cards that have memory errors and they know also the real faulty chip so we can check if script works ? thanks ; read up how to use it ; ty
ilie321
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 03 апр 2020, 11:00 |
galkinvv писал(а): I have a correspondence only for sapphire rx470 4gb - viewtopic.php?p=746565#p746565 Quote: First problem at: 0x0-0x1f0 - U2200+U2300 First problem at: 0x200-0x3f0 - U2000+U2100 First problem at: 0x400-0x5f0 - U2400+U2500 First problem at: 0x600-0x7f0 - U2600+U2700
any other cards to test?
Kassiopay
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 10 апр 2020, 03:12 |
Зарегистрирован: 13 янв 2020, 01:41 Наличности на руках: 34.61
Сообщения: 72 Откуда: Россия
I will also help the project! I will translate through Google, so I immediately apologize for the crooked translation! 1) If you leave a comment at the end of the script: Цитата: os.system("setfont") , then when you execute the script on the video card that is currently active, you will get unreadable text! 2) If you specify a volume of more than 1 MB for the test, errors on clearly good cards fall! Окажу и я помощь проекту! Переводить буду через Google так что сразу прошу прощения за кривой перевод! 1) Если в конце скрипта строки: Цитата: os.system("setfont") оставить закомментированными, то при выполнении скрипта на видеокарте которая активна в данный момент получится не читаемый текст! 2) При указании для теста объема более 1 Мб валятся ошибки на заведомо исправных картах!
ilie321
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 10 апр 2020, 08:30 |
Kassiopay писал(а): 1) If you leave a comment at the end of the script: Quote: os.system("setfont") , then when you execute the script on the video card that is currently active, you will get unreadable text! 2) If you specify a volume of more than 1 MB for the test, errors on clearly good cards fall! hello friend thank you 1 for me it is working ok can you show me what error? 2 i don't have any good amd card to test :)
Kassiopay
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 12 апр 2020, 17:07 |
ilie321 писал(а): for me is working fine Which Linux do you use? Give me a link... ---------- Добавлено спустя 1 минуту 50 секунд: ---------- ilie321 писал(а): https://drive.google.com/open?id=1_EkxW ... sbevbvEEAu This?
ilie321
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 13 апр 2020, 08:17 |
Kassiopay писал(а): This?
yes ; use it also; use rufus and white to usb; put dmgg.py on root of the usb after
Kassiopay
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 13 апр 2020, 13:36 |
ilie321 писал(а): yes ; use it also I tested on your Linux, the results are the same, tested on 2 different working graphics cards: ---------- Добавлено спустя 9 минут 14 секунд: ---------- I checked many times, this error appears only when the screen is completely painted over! Therefore, these errors come from the cursor !!! Therefore, I propose to develop some kind of cursor detector, and if the errors coincide, then ignore ...
Kassiopay
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 13 апр 2020, 14:28 |
ilie321 писал(а): i'm not so good at python I'm generally zero in python :) In C ++, another thing!
galkinvv
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 13 апр 2020, 17:57 |
From photo it looks that you have amdgpu video driver succefully initialized (mostly this problem appears when your are experementing with working card, cince on card with memory problems amdgpu fails to init). Both script and driver tries to manage gu memory, and it mecaomes a mess. For this case you have two alternatives: - disable amdgpu driver. Add amdgpu.modeset=0 nomodeset to kernel cmdline in grub.
- Test memory via amdgpu driver - test 7 MB framebuffer instead of physical memory.
For this /dev/fb0 shoulde be used instead of /dev/mem Use MEM=fb0 python3 ./dmmg.py 0 7 8
(note zero offset, unlike physical memory) Before testing Press Enter enough times to put blinking cursor to last line, so it won't overlap with testing area.
intell2000
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 13 апр 2020, 19:28 |
Зарегистрирован: 21 май 2018, 03:33 Наличности на руках: 28.24
Сообщения: 162 Откуда: ростов-на-дону
Kassiopay писал(а): I checked many times, this error appears only when the screen is completely painted over! Therefore, these errors come from the cursor !!! if you carefully read the original instruction of the source script - you will notice, that test must be applied only to SECOND card in system. if you start using test as i describe - this problems will gone
