Текущее время: 20 май 2024, 15:24
 Заголовок сообщения: Lenovo Thinkpad 13 (DA0PS9MB8E0 REV:E) Error Beeps
СообщениеДобавлено: 08 апр 2019, 13:18
Hello everyone, an attempt was made to read the EC controller (IT8886HE) with SVOD1, programmer was unable to read the chip but now the laptop is beeping. I have attached the error audio file. Please check and let me know what to do. Thanks in advance.
Posted after 1 hour 47 minutes 1 second:
Ì really want to know if anyone has had success reading IT8886HE with SVOD1 programmer..
 Заголовок сообщения: Re: Lenovo Thinkpad 13 (DA0PS9MB8E0 REV:E) Error Beeps
СообщениеДобавлено: 09 апр 2019, 13:08
This multicontroller programmin with SVOD well ...
BUT you have a different thikness and step of keyboard connectors on logic board and flex cable from sub board of programmer to logic board/
that is why from 4-5 pins of old flex cabel of programmer connetct2 pins together or no pins...
just make some measure via multimeter from one to 30 pin of key board connector to programmer connetcor and you can see that is flex cable have fater pins than mlb KB connector..
---------- Добавлено спустя 3 минуты 43 секунды: ----------
my reccomendation to you if you have 2nd SVOD version programmer: made a wire mount with conductors from programmer to you EC on board like in nm-a311 board pins with same EC
and programming you EC...
не будьте дампоепами...
 Заголовок сообщения: Re: Lenovo Thinkpad 13 (DA0PS9MB8E0 REV:E) Error Beeps  [РЕШЕНО]
СообщениеДобавлено: 11 апр 2019, 21:23
Thank You for the reply. I will take a second look at the connections.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo Thinkpad 13 (DA0PS9MB8E0 REV:E) Unable to Program IT8886HE
abuholm
16 июл 2019, 16:43
abuholm Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP DesignJet Z6100 Main PCA error (Main Board, Formatter) 7 beeps
service print
04 июн 2019, 16:40
Mishel01 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. thinkpad R60 (не нашел) error 2100 Detection error on HDD0 (main HDD)
al51al51
5555
05 авг 2019, 00:25
В этой теме нет новых непрочитанных сообщений. Lenovo Thinkpad L460 (NM-A651 Rev 1.0) Error 0189 Invalid Rfid Configuration Information Area Thinkpad
Дмитрий Селиверстов
18 июн 2023, 12:49
Brtth Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo V580C Ошибка 0271 Real Time Error. Fan Error
inferno3086
03 июн 2020, 15:53
inferno3086 Перейти к последнему сообщению
Сейчас этот форум просматривают: erikalov, hunter_nick, kulemet, sergey0102, SergeySN, tolkiengen и гости: 22
