Заголовок сообщения: Re: problem asrock z97 killer
Добавлено: 25 янв 2019, 16:28
Зарегистрирован: 12 дек 2015, 00:02 Наличности на руках: 71.61 Сообщения: 394 Откуда: Serbia Заблокирован
ok ,i will do it ..Also i have some problem on one board asus p8h61-mx when turn on i have beep code no ram ..I have check slot voltage everthing is ok ?maybe you have some idea?
aleksros
Добавлено: 26 янв 2019, 22:28
good news ,i just removed pwr controller and again solder and everthing start work ..
bokin021
Добавлено: 03 фев 2019, 20:45
aleksros intel DX79TO Maybe you have schematic or board view ?I dont have enable on pwr controller and cant find from come from signal.I search but i colud not find board view..
aleksros
no, I don't have schematic or boardview for Intel motherboard.
bokin021
Добавлено: 08 фев 2019, 22:07
aleksros hi ,i please you if you can help for some problem ..I have motherboard ga-h61m-ds2 ,I will send you schematic because no board view for this model..Ok ,problem is that on phase CPU coming instead 1.1 v is 2.7v , I folow vcore line also is 2.7 v ,I alredy have change PWM controller but same ..I never before have this problem ,very strange..Maybe you can advise me ..PS VR-on is ok 1.1 V.. Posted after 16 minutes 32 seconds: this is pictures of motherboard and voltage ..
aleksros
are you have oscilloscope? you have to see pulse voltage on DL2, DL3, DL5. not constant voltage, pulse - is ok. look around PWM DU1. SMD elements must be ok. no scratch or damage.
bokin021
Добавлено: 09 фев 2019, 00:25
no,i dont have oscilloscope ,but any way is to hi voltage?I have watch around but, nothing is damage ..,there is maybe another way ?
aleksros
yes. 2.7v - it's to hi. measure all mosfet's gate-source, drain-source. measure all smd near pwm du1 and voltage on pwm du1 pin's from 1 to 40 (page 27).
bokin021
Добавлено: 19 фев 2019, 14:47
may be that help you? i don't guru bios for notebook on future - create a topic in the relevant section, so you can get the answer as soon as possible.
bokin021
Добавлено: 19 фев 2019, 23:23
ok ,thanks lot..I m so sory ..I will open new section..
Сейчас этот форум просматривают: Google [Bot] и гости: 4
