Текущее время: 02 июн 2024, 04:12
 Заголовок сообщения: HP CQ56 (DAAX3MB16A1 rev:A) shutdown and sleep problem
СообщениеДобавлено: 24 май 2016, 00:56
Hi...
HP CQ56 DAAX3MB16A1 rev:A
Laptop was dead...I have changed kbc controller and bios chip and laptop now works ok, but when you click on shutdown it shuts down normaly but it starts again...
Basically it restarts itself normaly...When i put it in sleep mode...screen goes black normaly but it actually restarts itself,hard shutdown than start...
All signals on kbc looks normal to me...Any idea before messing with southbridge ???
Thanks...
 Заголовок сообщения: Re: HP CQ56 (DAAX3MB16A1 rev:A) shutdown and sleep problem
СообщениеДобавлено: 24 май 2016, 05:37
Please check the revision number of the original EC chip and the one you've installed. Described symptoms can appear if the EC installed is of different revision. Recently, there have also been reports about counterfeit ECs with changed revision marking from China.
СообщениеДобавлено: 24 май 2016, 11:53
EC is taken from donor board...it`s exact same revision as original...i even changed it twice...same problem...
This board came originally with 1mb cfeon bios chip...no metter what dump i have put...i wouldn`t get video on screen...
i have replaced it with 2 mb winbond same speed (again from same donor board ) and put newest bios from hp support and it worked...
I don`t now if that can impact strange shutdown behavior...
СообщениеДобавлено: 24 май 2016, 14:20
newest bios 2 mb? it imposible. it must be ONLY 1mb. if you have't flash on 1mb you also may write in flash two dump on 1mb. make it in hex editot. just dublicate originan bios twice.
SVOD, Siglent 1022DL, Victor 88B, программатор LPT(SPI TT), Lukey 853D, Win&MacOS. PCAD,
СообщениеДобавлено: 24 май 2016, 16:02
Very possible actually...model number cq56 150sm...you can check it yourself...2mb after decrypt... and i have fully working board aside with the same bios chip...
But this board is nightmare...It`s not worth but i`m kinda keen to fix it...
I have changed southbridge and laptop shuts down properly...so first problem fixed but after heating the board video driver stops responding and video freezes,resolutin is bad...i have found short on nb...
It`s for changing now...i`ll let you now the results...
СообщениеДобавлено: 24 май 2016, 21:49
That's indeed a hell of a board! Do you know what exactly led to such global failure?
СообщениеДобавлено: 27 май 2016, 20:30
After nb change laptop works as it should... :-ok-:
Had to change it twice,first donor was faulty...real torture... :ny_tik:
Well i belive that nb from start was the issue...short in 1.05v line...
Thanks for all responses. :a_g_a:
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. CQ56-228SR (DAAX3MB16A1 REV.A (Quanta AX3)) Нет изображения (Post code 2F)
Fizikzver
3902
20 авг 2014, 19:18
В этой теме нет новых непрочитанных сообщений. Продам MB от Compaq CQ56-103ER DAAX3MB16A1 rev:А
rks
24 окт 2016, 07:00
rks Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP CQ56-142SF (DAAX3MB16A1 REV:A) BIOS
habibou11
10 мар 2016, 15:06
habibou11 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP CQ56 (DAAX3MB16A1 rev: a) Просаживает, не понятно кто
fredy-87
2388
26 мар 2016, 15:40
fredy-87 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. cq56-230sr (daax3mb16a1 rev a) bios
akimov_aleks
04 май 2016, 16:08
dodo1 Перейти к последнему сообщению
Сейчас этот форум просматривают: Darkshadoff, minotaur, Yandex [BOT], yusuf4511 и гости: 29
