Fujitsu Lifebook AH530 (DA0FH2MB6E0) Hot to remove bios password https://vlab.su/viewtopic.php?f=57&t=26844 |
mun4o [ 01 дек 2014, 22:54 ] | |
Заголовок сообщения: | Fujitsu Lifebook AH530 (DA0FH2MB6E0) Hot to remove bios password |
Hi chaps, i found a way how to unlock the bios of Fujitsu Lifebook AH530 if pass-worded This is it, Bios pass is stored partly in to the SMBus controller - ITE IT8502e and another part in the u22 chip SPI memory in my case its Winbond W25Q16. Basically i reprogrammed the memory chip with dump taken from another machine and then i replaced the SMBus controller with another one and there you go it all works well. I am sure this metod can work on any other machine with the same problem. Good luck Regards |
o_elshad [ 25 дек 2014, 01:14 ] | |
Заголовок сообщения: | Re: Fujitsu Lifebook AH530 (DA0FH2MB6E0) Hot to remove bios password |
HI PLIZ DUMP AH 530 ( DAFH2AMB6G0 REV G) |
mun4o [ 10 фев 2015, 02:22 ] | |
Sorry m8, i don't have it Posted after 4 minutes 25 seconds: Oh my mistake , go to topic ID 6570 or in Fujitsu-Siemens: BIOS & EC dumps and down load it from there. Good luck |
