Заголовок сообщения: Dv2000 Wistron Tibet does not power on
Добавлено: 18 мар 2013, 10:33
Зарегистрирован: 17 мар 2013, 15:22 Наличности на руках: 30.00 Сообщения: 198 Откуда: Ghana
Hi everyone, this laptop has 3v and 5v on the coils and also has 3v on the power switch and voltage drops to 0v when pressed. There is no short on the board and the battery charges. I have reprogrammed the bios but still no response to the power switch. Where do I proceed from here?
Заголовок сообщения: Re: Dv2000 Wistron Tibet does not power on
abuholm
Добавлено: 18 мар 2013, 19:59
Thanks, but I have already done that but still no response. Anything else I should check?
Check LID_CLOSE# AD_IN# PM_RSMRST# PM_SLP_S3# PM_SLP_S5# Then check PWRBTN#_MCP before and after power button pressed.
abuholm
Добавлено: 19 мар 2013, 20:58
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 35
