Текущее время: 13 май 2024, 04:43
 Заголовок сообщения: ASUS GTX 960 - power gone after plugging 6 pin 12V connector
СообщениеДобавлено: 11 фев 2019, 18:03
Good afternoon,
I have problem with Asus GTX 960. There are no power on GPU and Memory. That is why I changed two components marked by green square on the front pcb. When the power doesn't apear I lifted GPU but it didn't change anything.
Once I forgotten plug the 6 pin connector and I measured powers on GPU and Memory. I was surprised that everything is ok. However, after I plug 6pin connector the powers have gone. Then I started measured INA3221 on the back of PCB (marked as green square). I changet it to new one. I found the broken resistors (marked red arrows). Two resistors under capacitor was replaced by 2x 20ohm. I have asus gtx 970 where are similar situation and there are 20ohm each. However, I dont know the resistor R1130 and I used 150ohm.
Now I have situation that when the 6pin is conected I haven't power on gpu and memory.
There are no shorts. The powers 12V 5V 3,3V present. What I schould check now?
I have to stress that GPU is lifted so I can't check screen without 6pin connector. I would like to solve it first and then I will put GPU back.
Is anyone have any idea?
Is anyone know which (size) resistor schould be used on R1130 and R1129?
 Заголовок сообщения: Re: ASUS GTX 960 - power gone after plugging 6 pin 12V connector
СообщениеДобавлено: 07 мар 2019, 23:55
Hello friend, you can look for the equivalent resistors on this two schematics. INA3221 circuit is preety much the same in all video cards. You should also look for the enabling signals of the GPU and Memory IC power controllers, and trace back what is getting those signals low. Hope it help. Let me know how it goes.
СообщениеДобавлено: 13 мар 2019, 03:08
did you check if there is a short circuit on the mosfets
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Матрицы ePD 33-pin. Отличия от ePD 30-pin. Как подключить ePD 30-pin на 33-pin.
в форуме Toshiba
vlev45
10 июн 2018, 06:56
В этой теме нет новых непрочитанных сообщений. I'm looking for 50 pin LVDS connector
в форуме Куплю | Buy
latitude
03 сен 2022, 23:11
Rein Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo X230 (ldb-2 mb 11232-1) No picture on LCD after short with fan connector
derick
14 май 2020, 19:54
richk Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. F5-572g (quanta zrw) when convert to legacy from uefi,display gone
simpleboy123
1614
14 июн 2018, 14:39
simpleboy123 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo G565 (Compal) Переделка вентилятора 4 pin в 3 pin
arjuk
23 июл 2014, 13:28
kaliyan Перейти к последнему сообщению
Сейчас этот форум просматривают: Sa1FeR и гости: 12
