Зарегистрирован: 21 сен 2022, 10:51 Наличности на руках: 15.00 Сообщения: 12 Откуда: Australia
Remove component from board and check if those pins on the board are still connected to GND. If not, component is bad. If there is still continuity to GND on the board without this component, the component is likely good (but may have been killed by whatever is shorting it). Have you tested all the mosfets yet?
