Installing kernel module...
MODS start: Thu Feb 12 23:06:25 2099
WARNING: -matsinfo is deprecated, because it is enabled by default, please remove it from command line
Command Line : gputest.js -oqa -test 3 -ignore_fatal_errors -run_on_error -matsinfo
CPU
Arch : x86_64
Name : Intel(R) Core(TM)2 Duo CPU E7500 @ 2.93GHz
Cores : 2
Version
MODS : 455.101
System
OperatingSystem: Linux (x86_64)
Kernel : 4.4.0-31-generic
KernelDriver : 3.87
SBIOS Version : 0502
SBIOS Date : 07/29/2010
HostName : vgatest
Available RAM : 550/992 MB (Free/Size)
Sys-uuid : 00020003-0004-0005-0006-000700080009
HDD-Serno : GYD031149
GPU 0 [01:00.0] dev.sub 0.0
DevInst : 0
PCI Location : 0x00, 0x01, 0x00, 0x00
GPU DID : 0x2504
PDI : 0x89f147a8e3340416
Raw ECID : 0x00c085c000000028129719c4
Raw ECID (GHS) : 0x4702812971800000017040180
ECID : SAMSUNG-SA1AN6-23_x8_y6
Device Id : _3YRG
Revision : a1
Sub Revision : 0
NV Base : 0xfd000000
FB Base : 0xe0000000
IRQ : 16
Smbus not found; toggling mask bit
ERROR: ** ModsDrvBreakPoint on GPU 0 [01:00.0] **
[ 0] ------------------------- BEGIN ASSERT INFO DUMP -------------------------
[ ] Successfully opened clockstest.jse
[ ] Successfully opened thermres.jse
[ ] Successfully opened vkstress.jse
[ ] Successfully opened perfpunish.jse
[ ] Successfully opened nvlink.jse
[ ] Successfully opened gpulist.jse
[ ] Successfully opened drf.he
[ ] Successfully opened idt.jse
[ ] Successfully opened resumehandler.jse
[ ] Compiling gputest.jse.
[ ] Compiled gputest.jse, pScript = 0x0xc966290.
[ ] Executing gputest.jse.
[ ] --->random2d.jse
[ ] Preprocessing random2d.jse.
[ ] Successfully opened random2d.jse
[ ] Successfully opened fpk_comm.he
[ ] Successfully opened fileid.jse
[ ] Compiling random2d.jse.
[ ] Compiled random2d.jse, pScript = 0x0xc3ae780.
[ ] Executing random2d.jse.
[ ] <---random2d.jse
[ ] --->reghalconst.jse
[ ] Preprocessing reghalconst.jse.
[ ] Successfully opened reghalconst.jse
[ ] Compiling reghalconst.jse.
[ ] Compiled reghalconst.jse, pScript = 0x0xc965780.
[ ] Executing reghalconst.jse.
[ ] reghalinternal.jse does not exist.
[ ] <---reghalconst.jse
[ ] pvstest.jse does not exist.
[ ] <gputest.jse
[ ] >oqa.spc
[ ] Preprocessing oqa.spc.
[ ] Successfully opened oqa.spc
[ ] Compiling oqa.spc.
[ ] Compiled oqa.spc, pScript = 0x0xc22d570.
[ ] Executing oqa.spc.
[ ] <oqa.spc
[ ] -matsinfo is deprecated, because it is enabled by default, please remove it from command line
[ ] Done parsing args
[ ] Command Line : gputest.js -oqa -test 3 -ignore_fatal_errors -run_on_error -matsinfo
[ ] CPU
[ ] Arch : x86_64
[ ] Name : Intel(R) Core(TM)2 Duo CPU E7500 @ 2.93GHz
[ ] Cores : 2
[ ] Version
[ ] MODS : 455.101
[ ] System
[ ] OperatingSystem: Linux (x86_64)
[ ] Kernel : 4.4.0-31-generic
[ ] KernelDriver : 3.87
[ ] SBIOS Version : 0502
[ ] SBIOS Date : 07/29/2010
[ ] HostName : vgatest
[ ] Available RAM : 550/992 MB (Free/Size)
[ ] NUMA Node 0 RAM: 550/992 MB (Free/Size)
[ ] Sysmem page size is 4 KB
[ ] Sys-uuid : 00020003-0004-0005-0006-000700080009
[ ] HDD-Serno : GYD031149
[ ] Turning off register exclusion regions.
[ ] >boards.jse
[ ] Preprocessing boards.jse.
[ ] Successfully opened boards.jse
[ ] Compiling boards.jse.
[ ] Compiled boards.jse, pScript = 0x0xcbb5cb0.
[ ] Executing boards.jse.
[ ] <boards.jse
[ ] CreateNvLinkLibInterface : Creating NvLink library interface NvLinkLibIfUser
[ ] CreateAllDevInterfaces : Created NvLink device interface NvSwitchDevIf
[ ] CreateAllDevInterfaces : Created NvLink device interface NvGpuDevIf
[ ] CreateAllDevInterfaces : Created NvLink device interface IbmNpuDevIf
[ ] Warning: Can't find Pci device with class code 0x68000, index 0
[ ] Find NvSwitch ports
[ ] -------Finish NvSwitch detection-----
[ ] Physical Graphics controller at 0000:01:00.0
[ ] reg virtual base = 0x7f8983000000
[ ] IOVA enabled
[ ] Detected 47 sysmem address bits for chip id 0xc06 at 0000:01:00.0, IOVA enabled
[ ] BAR0 base = 0x0_FD000000,
size = 0x01000000
[ ] BAR1 base = 0x0_E0000000,
size = 0x10000000
[ ] BAR2 base = 0x0_DE000000,
size = 0x02000000
[ ] Vendor ID = 0x10DE
[ ] Device ID = 0x2504
[ ] Chip ID = 0x00000176
[ ] [0000:01:00.0] cap id 0x5 found at offs 0x68
[ ] [0000:01:00.0] cap id 0x11 not found
[ ] Register manual file _3yrg_ref.txt not found
[ ] Warning: Can't find Pci device with class code 0x30000, index 1
[ ] Warning: Can't find Pci device with class code 0x30200, index 0
[ ] Find ibmnpu ports
[ ] -------Finish ibmnpu detection-----
[ ] Found Test Devices :
[ ] GPU 0 [01:00.0]
[ ] CreateAll : Created topology manager implementation TopologyManagerProtobuf
[ ] CreateAll : Created topology manager implementation TopologyManagerProtobufLR
[ ] CreateAll : Created topology manager implementation TopologyManagerAuto
[ ] Initialize : Topology file not specified, skipping.
[ ] Find bridge ports
[ ] [0000:00:01.0] bridge sec=01 sub=01 vendor=8086 devid=2e31 uniq_link_poll=false
[ ] [0000:00:1c.0] bridge sec=03 sub=03 vendor=8086 devid=27d0 uniq_link_poll=false
[ ] [0000:00:1c.2] bridge sec=02 sub=02 vendor=8086 devid=27d0 uniq_link_poll=false
[ ] Warning: Can't find Pci device with class code 0x60400, index 3
[ ] Find siblings at 0000:00:xx.x
[ ] Sibling found: domain=0000 sec=01 sub=01
[ ] Sibling found: domain=0000 sec=02 sub=02
[ ] Sibling found: domain=0000 sec=03 sub=03
[ ] Found chipset controller's port at 0000:00:01.0
[ ] [0000:00:01.0] cap id 0x10 found at offs 0xa0
[ ] [0000:00:01.0] extended cap id 0x1 not found
[ ] [0000:00:1c.2] cap id 0x10 found at offs 0x40
[ ] [0000:00:1c.2] extended cap id 0x1 not found
[ ] [0000:00:1c.0] cap id 0x10 found at offs 0x40
[ ] [0000:00:1c.0] extended cap id 0x1 not found
[ ] Root check: 0000:00:01.0 IsRoot=true
[ ] Connecting ports for Chipset 0000:00:01.0:
[ ] DP0 0000:00:01.0 connects to test device GPU 0 [01:00.0]
[ ] ------Finish bridge detection-----
[ ] InitializeAllDevices : RM not initialized, skipping GPU nvlink device initialization
[ ] GPU 0 [01:00.0] dev.sub 0.0
[ ] DevInst : 0
[ ] PCI Location : 0x00, 0x01, 0x00, 0x00
[ ] GPU DID : 0x2504
[ ] PDI : 0x89f147a8e3340416
[ ] Raw ECID : 0x00c085c000000028129719c4
[ ] Raw ECID (GHS) : 0x4702812971800000017040180
[ ] ECID : SAMSUNG-SA1AN6-23_x8_y6
[ ] Device Id : _3YRG
[ ] Revision : a1
[ ] Sub Revision : 0
[ ] NV Base : 0xfd000000
[ ] FB Base : 0xe0000000
[ ] IRQ : 16
[ ] MSI-X not supported on GPU 0 [01:00.0], skipping
[ ] Detected supported interrupt types: legacy MSI
[ ] IRQ statistics:
[ ] num IRQs: 10
[ ] avg IRQ delay: 0us
[ ] min IRQ delay: 0us
[ ] max IRQ delay: 0us
[ ] Legacy interrupts verified OK
[ ] IRQ statistics:
[ ] num IRQs: 10
[ ] MSI verified OK
[ ] Skipping MSI-X verification
[ ] Hooking MSI
[ ] [0000:01:00.0] cap id 0x10 found at offs 0x78
[ ] Warning: Can't find Pci device with class code 0x40300, index 2
[ ] Bypassing unsupported vendor: 0x8086Device already uninitialized
[ ] _3YRG Azalia: DeviceId: 0x228e.
[ ] Found 1 controllers (DevId 127)
[ ] SetAspm on GPU: 0x11010041
[ ] Reset polled 2 times in 0 us on AzaRegWaitPoll and returned 0.
[ ] Found codec on sdin 0
[ ] The codec contains 1 function group(s).
[ ] PEX: set downstream ASPM=0x51010041
[ ] DRAM info read from PreOS PBI not supported
[ ] Failed to get DRAM information from VBIOS preOS PBI. Will attempt to read from the DRAM.
[ ] NVRM: Child aperture crosses parent's boundary, length 925696 offset 0, Parent's length 0
[ ] NVRM: Child aperture crosses parent's boundary, length 1024 offset 0, Parent's length 0
[ ] Setup dma base only supported on PPC, skipping
[ ] ACPI: Unable to evaluate dev method _DSM on 0000:01:00.0
[ ] Warning: Can't find Pci device with class code 0xc0500, index 0
[ ] Smbus not found; toggling mask bit
[ ] SMBus controller Not found
[ ] ACPI: Unable to evaluate dev method _PR0 on 0000:00:01.0
[ ] NVRM: OBJVBIOS: Unknown BIT token 0x45! Skipping...
[ ] NVRM: Revlock: VBIOS or RM Revlock level too low.
[ ] NVRM: MinimumRmRevlockLvl: 18
[ ] NVRM: currentRmRevlockLvl: 16
[ ] NVRM: minimumVbiosRevlockLvl: 0
[ ] NVRM: CurrentVbiosRevlockLvl: 0
[ ] NVRM: bp @ <fileid:0x0001ac>:2804
[ ] ** ModsDrvBreakPoint on GPU 0 [01:00.0] **
[ 0] -------------------------- END ASSERT INFO DUMP --------------------------
Error 000000000542 : Gpu.Initialize NVRM VBIOS invalid or rejected [0.575 seconds]
Error 000000000542 : Global.PrintGpuInitError NVRM VBIOS invalid or rejected [0.000 seconds]
Error 000000000542 : Global.InitializeGpuTests NVRM VBIOS invalid or rejected [0.580 seconds]
ERROR: Unable to determine current VGA mode, ax=0x4f03
ERROR: ** ModsDrvBreakPoint **
[ ] ------------------------- BEGIN ASSERT INFO DUMP -------------------------
[ ] <gputest.jse
[ ] >oqa.spc
[ ] <oqa.spc
[ ] CPU
[ ] Arch : x86_64
[ ] Cores : 2
[ ] Version
[ ] MODS : 455.101
[ ] System
[ ] >boards.jse
[ ] <boards.jse
[ ] IOVA enabled
size = 0x01000000
size = 0x10000000
size = 0x02000000
[ ] GPU 0 [01:00.0]
[ ] DevInst : 0
[ ] Revision : a1
[ ] IRQ : 16
[ ] IRQ statistics:
[ ] num IRQs: 10
[ ] IRQ statistics:
[ ] num IRQs: 10
[ ] MSI verified OK
[ ] Hooking MSI
[ ] First error recorded: 818 Mods detected an assertion failure
[ ] JavaScript stack trace:
[ ] #0: Initialize() in <native>:0
[ ] #1: InitializeGpuTests() in gputest.jse:331
[ ] #2: gputest_main() in gputest.jse:2199
[ ] #3: main() in gputest.jse:2136
[ ] NVRM: Vbios Init failed
[ ] Error 000000000542 : Gpu.Initialize NVRM VBIOS invalid or rejected [0.575 seconds]
[ ] Error 000000000542 : Global.PrintGpuInitError NVRM VBIOS invalid or rejected [0.000 seconds]
[ ] Error 000000000542 : Global.InitializeGpuTests NVRM VBIOS invalid or rejected [0.580 seconds]
[ ] NVRM: *** Unable to call VBIOS, no boot GPU device
[ ] Unable to determine current VGA mode, ax=0x4f03
[ ] Unable to retrieve current VESA mode, will use mode 3
[ ] NVRM: Clear VBIOS notify (VBIOS will handle hotkeys, etc.).
[ ] NVRM: function not initialised properly
[ ] NVRM: Assertion failed: 0x00000000017ddd4a
[ ] ** ModsDrvBreakPoint **
[ ] -------------------------- END ASSERT INFO DUMP --------------------------
[ ] <gputest.jse
[ ] >oqa.spc
[ ] <oqa.spc
[ ] CPU
[ ] Arch : x86_64
[ ] Cores : 2
[ ] Version
[ ] MODS : 455.101
[ ] System
[ ] >boards.jse
[ ] <boards.jse
[ ] IOVA enabled
size = 0x01000000
size = 0x10000000
size = 0x02000000
[ ] GPU 0 [01:00.0]
[ ] DevInst : 0
[ ] Revision : a1
[ ] IRQ : 16
[ ] IRQ statistics:
[ ] num IRQs: 10
[ ] IRQ statistics:
[ ] num IRQs: 10
[ ] MSI verified OK
[ ] Hooking MSI
[ ] <gputest.jse
[ ] >oqa.spc
[ ] <oqa.spc
[ ] CPU
[ ] Arch : x86_64
[ ] Cores : 2
[ ] Version
[ ] MODS : 455.101
[ ] System
[ ] >boards.jse
[ ] <boards.jse
[ ] IOVA enabled
size = 0x01000000
size = 0x10000000
size = 0x02000000
[ ] GPU 0 [01:00.0]
[ ] DevInst : 0
[ ] Revision : a1
[ ] IRQ : 16
[ ] IRQ statistics:
[ ] num IRQs: 10
[ ] IRQ statistics:
[ ] num IRQs: 10
[ ] MSI verified OK
[ ] Hooking MSI
[ ] >oqa.spc
[ ] <oqa.spc
[ ] CPU
[ ] Arch : x86_64
[ ] Cores : 2
[ ] Version
[ ] MODS : 455.101
[ ] System
[ ] >boards.jse
[ ] <boards.jse
[ ] IOVA enabled
size = 0x01000000
size = 0x10000000
size = 0x02000000
[ ] GPU 0 [01:00.0]
[ ] DevInst : 0
[ ] Revision : a1
[ ] IRQ : 16
[ ] IRQ statistics:
[ ] num IRQs: 10
[ ] IRQ statistics:
[ ] num IRQs: 10
[ ] MSI verified OK
[ ] Hooking MSI
MODS is exiting with failure after assert #5. Breakpoint limit exceeded.
Error 000000000818 : Global.RunFuncOnlyOnce Mods detected an assertion failure [0.000 seconds]
Error 000000000818 : Global.VerifyErrorCode Mods detected an assertion failure [0.000 seconds]
Error Code = 000000000818 (Mods detected an assertion failure)
Error 000000000818 : Global.PrintErrors Mods detected an assertion failure [0.000 seconds]
Error 000000000818 : Global.PrintVbiosStatus Mods detected an assertion failure [0.000 seconds]
Error 000000000818 : Global.PrintGpuTestErrors Mods detected an assertion failure [0.002 seconds]
RmDestroyGpu failed
