Текущее время: 18 май 2024, 10:56
 Заголовок сообщения: ASUS 1080TI turbo PEX Reset продолжить ниже поток
СообщениеДобавлено: 25 авг 2021, 13:26
привет, я хочу рассказать небольшую историю, потому что я закрыл обсуждение, а теперь заблокировано. Пришел 1080 ti asus turbo, все измерения в порядке (напряжения и импеданс_, GPU нагревается, но через 1-2 минуты.
На выводе PCI Pex_Reset было измерено сопротивление 6 Ом. Эта плата не буферизована. Я не сдавался. Я пробовал переплавку. Теперь PEX_Reset составляет 7кОм и плата исправна.
Это может случиться.
Спасибо пользователю Pandemonium6 за помощь.
 Заголовок сообщения: Re: ASUS 1080TI turbo PEX Reset продолжить ниже поток
СообщениеДобавлено: 25 авг 2021, 19:59
Haha I was thinking why did you close the topic :-)
https://www.theguardian.com/technology/ ... ngineering
Maybe it was a whisker. This is effect when a tin needles build up along the electric field. PEX_RESET is +3.3V so it maybe was a 6 ohm whisker to the ground.
6 ohms is rather a strange value. This is normally open circuit when the semiconductors are fried in I/O pins, at least all pis I have found damaged look like open or almost open.
There is another way to burn such a whisker by a strong current. This PEX_RST pin is 3.3V capable so you could connect 1-3V directly from the power supply and it should not do anything wrong. Logic level is to weak to do it but by a direct PSU voltage should burn it as a fuse.
It is risky because if there is something stronger like a liquid metal you would burn PCB.
So the first should be IPA + compressed air and then maybe 1Volt from the power supply. 1V from the PSU definitely would burn such whisker and should not fry the PCB. Soldering on a proper reflow machine is the safest and at once will repair all other joints.
I set a profile and when it reaches the reflow phase above 200'C I wait to cross 220..225..230.. and I start touching the chip. When I feel the chip is floating I stop the process and let it to cool. I press te "red" button on the Chinese reflow machine, nothing special IR6500 but it is enough plus flux 218 noname clear, transparent. I put flux around the chip, a lot of flux, then 10 minutes preheating from the bottom only to remove moisture and so on some minutes at 110'C to be sure that no popcorning will happen...
В этой теме нет новых непрочитанных сообщений. Gigabyte GTX 1080 Turbo - 4.5ohm on PEX rail?
maplesyrup
16 май 2023, 08:36
maplesyrup Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Я не могу продолжить установку Windows 10, потому что она останавливается на контрольных вопросах, а не на про
в форуме Программное обеспечение | Software
eletmoraes
16
2549
29 мар 2023, 00:22
Bulat01 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Tемпературу и поток воздуха
Jane1
15 апр 2022, 11:53
Tester500 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. WEP 853AAA I - перестал регулироваться поток воздуха фена
в форуме Оборудование для ремонта | Repair Equipment
TINT
18 янв 2024, 20:44
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS 1080Ti Turbo сбиты элементы
madking
13 апр 2020, 17:49
Сейчас этот форум просматривают: buyanigor, evgenyjp, Fr3shGy, psyche, Service и гости: 16
