Текущее время: 10 июн 2024, 14:44
 Заголовок сообщения: GTX 1070 no HDMI display after driver loaded. GPU issue?
СообщениеДобавлено: 29 ноя 2020, 04:37
Hi, i'm facing a strange issue with a 1070 graphics card and would like to know if someone else had a similar problem.
The card is working fine but after the system has loaded the driver, the video output through HDMI port stop working, but if I plug into DP or DVI it works just fine.
This means that the GPU is faulty or might be something else?
Thanks in advance!
 Заголовок сообщения: Re: GTX 1070 no HDMI display after driver loaded. GPU issue?  [РЕШЕНО]
СообщениеДобавлено: 29 ноя 2020, 07:09
Is max resolution of attached monitor 1920x1080 or higher? Try another if possible.
(I have a 2560x1440p monitor that fails to display on amd cards over hdmi after driver load on linux, but dvi dual link and DP works fine. It is old and has "incorrect"/"problematic" EDID)
Also check that vbios info about connectors in GPU-z corresponds to physically present.
СообщениеДобавлено: 03 дек 2020, 05:46
Thank you, i'll have a better look soon.
PS: I've tested at a 1280x1020, 1080p and 2k monitor, and didn't worked, but didn't tried to rewrite bios.
СообщениеДобавлено: 06 дек 2020, 10:29
I've flashed a new bios and the HDMI now works again.. i've bought it as a faulty card and it had a strange issue before, and sice the card was working on DP and DVI, bios was the last of my thoughts. Thank you!
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Samsung keyboard maping issue NP450R5E (ramos) keyboard maping issue
в форуме Samsung
minanpil13
03 апр 2019, 10:30
minanpil13 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. How to resolve HP Printer Driver is Unavailable issue
jamesenderson
07 сен 2019, 11:18
jamesenderson Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus X72D (K72DR Rev 3.0) no display issue
mohkam3000
08 авг 2015, 02:14
mohkam3000 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Next GT440 2GB artifacts after loading video driver
FRD
3385
22 окт 2016, 22:17
makarog Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. B50-70 (LA-b091p) hang after install intel driver
egyeprom
28 дек 2016, 17:28
i001546 Перейти к последнему сообщению
Сейчас этот форум просматривают: fenix86rus, Google [Bot], TeamNEIR, zhur36 и гости: 14
