Hi i have RX 580 with elpida memory. I get very large screen at startup and black screen in windows. I have tried flashing org bios. Memory resistance 32 ohm.
galkinvv
Заголовок сообщения: Re: RX 580 4GB Strange problem
Make a thorough review of the video outputs, apparently DVI damaged pin's. Check the power supply on the video outputs (5 volts DVI and HDMI and 3.3 volts DP) then check the clock and date for all video outputs. write the exact model and manufacturer of the video card, so it will be easier to help you.
menzy
