Текущее время: 01 июн 2024, 22:20
 Заголовок сообщения: Zotac gtx 1070 Ti Mini Help No display Indentification Elemen  [РЕШЕНО]
СообщениеДобавлено: 19 янв 2022, 05:26
Need help
Zotac gtx 1070 Ti Mini - NO Display
All power rise, except for vram (controller by RT8816), try to replace RT8816 but still power not rise
Resistor 2R2 burned before (2 pcs, back near RT8816 and front under coil vram), already change them but same result
1. Resistance pcie line 3.3v very low, 14 Ohm, 0.029 on diode. but power 3.3v rise appear
2. Front Top left card, AAM7MB very hot. without this AAM7MB Resistance pcie line 3.3v still low
1. Resistance pcie line 3.3v very low, Problem with chip gpu? or any idea where to start digging
2. any one known what this part AAM7MB? datasheet
https://ibb.co/t4GVKR4
https://ibb.co/V27ZYNW
 Заголовок сообщения: Re: Zotac gtx 1070 Ti Mini Help No display Indentification Elemen
СообщениеДобавлено: 19 янв 2022, 07:16
aam7mb - replacement apl3516
resistance 1.8 and 1.0 ???
check signal lines pcie and dp-hdmi-dvi on gpu side.
СообщениеДобавлено: 19 янв 2022, 07:47
thks u
1.8v 530 Ohm / 0.470 diode
1v 25 Ohm / 0.043 diode
Chip gpu? 1070 arround 900 Ohm on 1.8v right?
sorry, which one i suppose to mesure? dont know
СообщениеДобавлено: 19 янв 2022, 08:43
working videocards ~ 100 Ohm.
check - POSSIBLE problem with pex power 1.0v ic >>>> low resistance 3.3v
СообщениеДобавлено: 19 янв 2022, 13:49
You have to find similar boardview from MSI since there are all of them on the forum. Locate 3.3V and look what is connected to this voltage rail. Also a thermal camera would be helpful.
You have to eliminate one by one. unsolder, measure, solder back.
СообщениеДобавлено: 19 янв 2022, 14:19
Thanks u
maybe i put wrong resistor value, do u know the value of this 2 resistor?
https://ibb.co/940yvYC
https://ibb.co/N66V1Gn
СообщениеДобавлено: 19 янв 2022, 16:24
As I said. Start from the beginning. Find MSI boardview which is similar. Track what is connected to this voltage rail and eliminate one by one.
В этой теме нет новых непрочитанных сообщений. Zotac RTX 3060 Ti Help Indentification Elemen
dani82
23 апр 2024, 00:43
dani82 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI GamingX RX 570 4GB Indentification Elemen
dani82
06 авг 2021, 05:11
swansic Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Need Help Idetification Elemen Sapphire RX 570 RX 470 480 marking S1AR
dani82
28 авг 2021, 17:39
В этой теме нет новых непрочитанных сообщений. Help Identification Elemen Altec PC410
в форуме Оборудование для ремонта | Repair Equipment
dani82
14 сен 2023, 09:06
felix2604 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Zotac GTX 1070 mini КЗ по 1.8V
Wheelwrigh
1868
29 июн 2019, 00:18
lantrung1983 Перейти к последнему сообщению
Сейчас этот форум просматривают: Opacky и гости: 26
