Текущее время: 10 июн 2024, 17:48
Страница 1 из 1 [ Сообщений: 2 ] |
huehu3gg
Заголовок сообщения: Gtx 1080 Aorus Artifacs with low voltage Добавлено: 04 июл 2023, 09:09 |
Сообщения: 30 Откуда: Argentina
Hi! the things is, got an gtx 1080 aorus. tipycal artifacs on the screen with little squares, some windows distortion... okey, i reball the chip.. and still the same. i try it to stress, and to my sorprise, there are no artifacs and you can play games or stress for hours! okey.. now why i got artifacs...? i found when the cards is in idle mode with 0.6v show artifacs. when card its about 0.845v no more artifacs, no matter the gpuz clock speed (i know cause i test high clock, low voltage, etc etc) the fact is when the voltage drop, artifacs show in windows desktop... so i think to "repair" this i need to change that idle voltage, from 0.6v to 0.845 aprox. and the card come back to life... its alive but with artifacs on low voltage. i repeat you can play games etc. its use up9511p for nvvdd. can someone give me some help to modifiy the idle voltage? its posible? Thanks
