samsung (np450r5e) battery not charging https://vlab.su/viewtopic.php?f=42&t=125699 |
1nteger [ 09 май 2022, 21:29 ] | |
Заголовок сообщения: | samsung (np450r5e) battery not charging |
samsung np450r5e motherboard ba41 02244a problem battery is not charging, battery is empty and battery replaced but it isnt fixx th problem ı tried everything with software operation or out and in tactics but nothing helps. ı have 20 pins charger IC ı think bq24735 how will ı go ahead from there.? ı dont have schematic. ı controled bq24735 cmsrc 1.9 v acdrv 1.9 and acok signal is sometimes 8.8v sometimes 1.3v is the problem bq24735 ? |
Виктор1985 [ 09 май 2022, 21:46 ] | |
Заголовок сообщения: | Re: samsung (np450r5e) battery not charging |
1nteger Hi, check your mail. Acok should be 3.3v ---------- Добавлено спустя 9 минут 57 секунд: ---------- 1nteger писал(а): cmsrc 1.9 v acdrv 1.9 Acfet and Rbfet are close Sorry for my english))) |
1nteger [ 09 май 2022, 22:33 ] | |
Виктор1985 писал(а): Acfet and Rbfet are close Sorry for my english))) thanks for answer. ı am the beginner for the repair. are they input fets ? ı dont have schematic. please pm me schematics about ba41 02244a sorry for waiting 1 hours ım new member and ı cant download anything. |
Виктор1985 [ 09 май 2022, 23:05 ] | |
Yes they are the inputs fets, they name on schema are tr562 and tr554, then they are close, laptop doesn't turn on, not just no charging battery, send to your mail the second file |
1nteger [ 09 май 2022, 23:37 ] | |
Виктор1985 писал(а): Yes they are the inputs fets, they name on schema are tr562 and tr554, then they are close, laptop doesn't turn on, not just no charging battery, send to your mail the second file okay friend thanks. ı checked and ı answer to you on mail pls check your mail and spam folder too ı checked there is short on two mosfets ı will upgrade later this subject. anyone has the pcb diagram on this motherboard ramos_14 Posted after 1 hour 10 minutes 58 seconds: 1nteger писал(а): laptop doesn't turn on, not just no charging battery laptop turning on with ac adapter. there is no problem laptop works fine with ac adapter. but not charge adapter and plug in but not charging fault. any others help for me ? |
Виктор1985 [ 10 май 2022, 09:35 ] | |
First what you must do, is checking your battery in another working laptop, or check another battery in your laptop. Then if all will be not ok, you shold wright here the measurements of all pins bq24735 when battery is connected, and we together will thinking what is the problem Sent boardview ---------- Добавлено спустя 11 минут 29 секунд: ---------- 1nteger писал(а): is short on two mosfets That is the problem, you need to fix this |
