Текущее время: 28 май 2024, 23:53
gurug
Заголовок сообщения: Re: Asus K51AC (AMD) Bios password? Добавлено: 30 окт 2016, 21:26 |
Зарегистрирован: 30 окт 2016, 20:12 Наличности на руках: 12.00
Сообщения: 6 Откуда: slovenia
gofer писал(а): Try 2BB1LBA1 Not working...
gurug
Заголовок сообщения: Re: Asus K51AC (AMD) Bios password? Добавлено: 30 окт 2016, 23:04 |
poluyretan писал(а): remove cmos battery not solve problem? No and also flashing did not help. Password still on...
gurug
Заголовок сообщения: Re: Asus K51AC (AMD) Bios password? Добавлено: 31 окт 2016, 12:40 |
Dimych писал(а): remote bois battery on 2-3 days, because matherboard have condensators, and they take charge. wait when they have worn I think it won't work, because when I took battery out, I also shorted + and - for few seconds, and pushed power button for 10 seconds ... that should discharge capacitors ... poluyretan писал(а): One variant solve the problem - reflash bios from bios dump which downloaded from another k51ac notebook
I got bios dump, how can I flash it? Do I need hardware flasher for that?
gurug
Заголовок сообщения: Re: Asus K51AC (AMD) Bios password? Добавлено: 31 окт 2016, 17:09 |
ZeReX писал(а): This device(ch341) can write eeprom. I don't have schematics of your motherboar, but I think bios password must be in bios flash. If you will write clean bios with programmer it will resolve your problem. Ok, just in case I contacted Asus - waiting if they will reply - if they have some kind of master password ... if they don't then only way is to buy flasher and try that. Thanks all, for your help.
