TVS Pressfit Diode BYZ50A* or BYZ35A* for Metabo impact wrench SSW LTX 600 https://vlab.su/viewtopic.php?f=4&t=130633 |
salomalo [ 29 ноя 2022, 20:31 ] | |
Заголовок сообщения: | TVS Pressfit Diode BYZ50A* or BYZ35A* for Metabo impact wrench SSW LTX 600 |
Hello, like I described above, I'm searching for a pressfit diode. Those are used on the switch of a metabo ssw ltx 600 aswell and I need to replace it. Manufacturer is Diotech. They call it Silicon Protectifiers with TVS characteristics High-temperature diodes. Cannot attach datasheet, but it can be found easily on google. Thanks in advance |
u666sa [ 29 ноя 2022, 23:55 ] | |
Заголовок сообщения: | Re: TVS Pressfit Diode BYZ50A* or BYZ35A* for Metabo impact wrench SSW LTX 600 |
salomalo писал(а): I'm searching for a pressfit diode Look on aliexpress. I found the 2nd one right away. You can also N rig a regular diode with same characteristics, perhaps. You search for BYZ50A or BYZ35A without *star* and you will find it. |
salomalo [ 02 дек 2022, 23:48 ] | |
u666sa писал(а): Look on aliexpress. I found the 2nd one right away Thank you for the help. But I can't find them on aliexpress. Can you kindly provide me a link? |
u666sa [ 03 дек 2022, 22:00 ] | |
salomalo писал(а): Can you kindly provide me a link? https://aliexpress.ru/item/33022165938.html?sku_id=67284536076 |
