box amplified subwoofer Newlink SP102 heating output https://vlab.su/viewtopic.php?f=23&t=87955 |
eletmoraes [ 19 мар 2019, 16:49 ] | |
Заголовок сообщения: | box amplified subwoofer Newlink SP102 heating output |
output TEA2025B and tda2822 have been replaced but continue heating the output. This handset used two left and right audio inputs and two outputs for smaller speakers plus a 15w 6 ohm speaker . I would like to replace every amplifier circuit using other components equivalent to the original circuit. I have in my workshop the TDA2030 amplifier, can I make an equivalent circuit? I wanted to set up another circuit using the 15w 6 ohms speaker, the two audio inputs (left and right) and two left and right outputs for speakers of 7.5cm or so in diameter . 12v AC power transformer and 15v DC voltage . Double volume potentiometer |
mia [ 19 мар 2019, 19:28 ] | |
Заголовок сообщения: | Re: box amplified subwoofer Newlink SP102 heating output |
Any sound amplifier produce heat. |
