GIGABYTE GA-H110-H https://vlab.su/viewtopic.php?f=223&t=140108 |
latinphoenix7 [ 06 фев 2024, 06:57 ] | |
Заголовок сообщения: | GIGABYTE GA-H110-H |
hELLO EVERYONE! GIGABYTE GA-H110-H REV. 1.0 Problem: Vcore =0V Diagnostics N_-PFMRST (PLTRST# PCH)---> LRESET# (I/O)= 0V PCH_PWROK= 3.3V SYS_PWROK= 3.3v N_-CPURST= 1V PCIE CLOCK A13 AND A14= 0.4V T_TPMCLK (TPM)= CHANGEABLE/INCONSTANT = MUTIMETER SHOWS 1 -- 6v PCH IS FRIED?? |
pEEp [ 06 фев 2024, 14:03 ] | |
Заголовок сообщения: | Re: GIGABYTE GA-H110-H |
latinphoenix7 писал(а): Problem: Vcore =0V PWM ISL95858 ? VTT_PWRGD (8) = ? VR_RDY (11) = ? V95858 (24) = ? + check R=2.2 Ohm (VCC 5v) |
latinphoenix7 [ 07 фев 2024, 02:24 ] | |
pEEp писал(а): PWM ISL95858 ? VTT_PWRGD (8) = ? VR_RDY (11) = ? V95858 (24) = ? + check R=2.2 Ohm (VCC 5v) Yes, the PWM is ISL95858 VTT_PWRGD (8)= 3V VR_RDY (11) = 3.3 V95858 (24) =5V (This voltage (5VDUAL comes from DAQ5) ISL95858_VIN(44)=12V 95858_VDDP (32)=5V SCLK (5)= 1V SDA (7)= 1V ALERT# (6)= 1V ETC ALL of PWM looks OK. N_CPUPWROK= 1V N_-CPURST= 0V I made a mistake on previous post I was watching "the power sequence# for H110/B150 (6ta Gen) and I saw that N_-PFMRST (PLTRST# PCH) doesnt come out of PCH. As you can see, Vcore (20) needs N_-PFMRST and CPURST# to come out |
