GeForce FX5700 vs. FX5700-V https://vlab.su/viewtopic.php?f=178&t=7430 |
Thomasing [ 14 июн 2012, 19:21 ] | |
Заголовок сообщения: | GeForce FX5700 vs. FX5700-V |
Hi friend, could I used GeForce FX Go5700 instead of FX Go5700-V? I have HP ZD7258ea with FX Go5700-V and i do not know, if FX Go5700 without "V" will work in this laptop. What is different between FX Go5700 and FX Go5700-V? Are the chips compatible and interchangeable? Thank you very much for your replies. |
тагансити [ 15 июн 2012, 14:19 ] | |
Заголовок сообщения: | Re: GeForce FX5700 vs. FX5700-V |
The chips FX Go5700 and FX Go5700-V are compatible and interchangeable, but power dissipation of FX Go5700 is much more then FX Go5700-V. You will need upgrade cooling system... |
Thomasing [ 16 июн 2012, 17:57 ] | |
ok... I understand. Thank you very much for your explanation :) |
