Текущее время: 20 май 2024, 01:42
 Заголовок сообщения: Asus 192S
СообщениеДобавлено: 31 окт 2013, 11:33
Privet.i can't speak russian verry well,but i know moldavian language verry well,so please respond in any language you want.
i have a problem with an Asus vw192S lcd.the autoadjust function moves the viewe area half way to left.if i set the freqency from pc to one higher than 75Hz the monitor shows normal screen position,without any problem,but the "out of range" square keeps floating around screen,so it's not an option.i've replaced all the capacitors,and on the "logic" board nothing seems defective.on the power board there are some areas browned from heat,but it works just fine.have someone found any similar problems in other monitors?
i will attach photos soon with the screen.
Posted after 1 hour 52 minutes 54 seconds:
here are some photos.please help :-(
 Заголовок сообщения: Re: Asus 192S
СообщениеДобавлено: 31 окт 2013, 21:43
Заблокирован
Give your email address :-):
«Кто владеет информацией - тот владеет миром»
СообщениеДобавлено: 02 ноя 2013, 11:49
my e-mail address is sebulica@yahoo.com
i've researched a little bit more and i think the main processor from logic board it has an defective firmware,or got defective,and is not positioning the image correctly.if i play with the phase and positioning i can get the image closer to center.but it still has about 8-10cm left of blackness.
СообщениеДобавлено: 02 ноя 2013, 12:03
Заблокирован
sebulica93,check e-mail
СообщениеДобавлено: 02 ноя 2013, 14:42
thank you for the dump of the processor firmware.but the problem is that the service i'm working at doesn't have ic programming tools.i'm willing to solve the problem but i'm preety limited.can you help me build my own programmer?
i have an arduino programmer from a project i've made in highschool.can i use that to rewrite the firmware in the chip? :)
it's a FTDI232 with mini usb
thank you for helping me out
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus G750JX (z) (Asus G750JZ ) Asus G750JX ----> Asus G750JZ
paveell
16
22747
04 дек 2016, 19:40
paveell Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS K40C (ASUS) ASUS K40C перестал включаться
immortal14
17
15788
23 ноя 2020, 20:09
immortal14 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ASUS (Asus F5V Rev 2.0) Asus F5V Rev 2.0 не стартует
jemand
14 дек 2015, 01:36
jemand Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus N71J (Asus N71JA Rev 2,1) Asus N71JA Rev 2,1 после залития
aplicator
11 апр 2016, 21:19
Anatoli4 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. asus x550c (asus x550c) asus x550c
VINT123
16 май 2016, 11:18
