I have a PCB with that MCU installed. Since no datasheet is available an I can't see what is it like, I am willing to buy one and replace to see if this will fix the problem.
There is only that mark on it - "Dueseldorf". Maybe it is codename of some MCU-family...
it is automotive device which has only this MCU on it - other ICs are TTL - I checked them - all working. So it is only thic IC to blame for not working...
kod.begemot
Заголовок сообщения: Re: MCU "Duesedorf"
Добавлено: 27 янв 2011, 14:27
Модератор
Зарегистрирован: 31 авг 2010, 08:13 Наличности на руках: 6,188.63 Сообщения: 381 Откуда: Краснодарский край
From a device this board? Need more information to try to help you ..
Sorry for not giving complete details in previous post! I had only PCB - it was brought to me by friend - it is from his car. Some computer that is not working - so car is not moving at all... Immobilizer or something ...
On PCB I described what is - this MCU and few TTLs which are OK. Power supply 5V - OK, oscillator - running... But board not working...
